chilipeppr/grbl
I can not generate G-code longer. If I set all parameters and click “Send G-code to Workspace” click, then nothing happens. My Workspace are empty.
Can you post a screenshot of what you’re talking about?
Perhaps try the http://chilipeppr.com/xpix workspace instead? Or can you show your Javascript console and see if an error is occurring such that the gcode generation function is crapping out and thus why you get no gcode? Then take a screenshot of that.
i drag and drop the brd in xpix and i can see the Generated G-Code. In grbl not.
I use Mozilla with new Updates.
How can I reset the settings, or delete the cache. Maybe that could solve my problem.
Open up your Javascript debug console. Go to the resources tab. Go to http://chilipeppr.com in the tree list. Inside that folder will be all your localStorage cache and you can delete all or some of it.
Sometimes i had the same bug, the gcode are not refreshed. You can try a shift+reload in ur browser window. But please start the js console and send us the js error, then we can help you.
Shift+Refresh dont work. in iExplorer dont work too, becouse drag and drop dont work. I have this bug only in /grbl. Tiny works.
How i can get the js console?
If you use windows 10? I guess the old IE run in a lot if problems. If u dont want to use chrome or firefox the try the “edge” explorer.
