Hey all,
I’m getting restarted after not having run the mill for about a year. I just re-flashed my Due with the latest version of g2core and rebuilt the latest SPJS (on a Macbook Pro). I can connect to the board fine using the /dev/tty.usbmodemxxx port, but the connection drops sporadically. Sometimes it works for a few minutes, sometimes it happens almost immediately. There is no message either in Chilipeppr or in the SPJS console, the port just gets unchecked. I can usually just check the port again and it will reconnect to g2core fine, so it’s not that the board locks up, but beyond that I don’t know what to do to troubleshoot it. It’s not usable as is given that if the connection drops during a job, it loses track.
Any ideas? Are there compile options in g2core that could cause this? (I have a custom board that I’m building for.)
Cheers,
/Patrik
