Hey Guys,
I had everything working so far, it’s been a while since i was using Chilipeppr.
So i had finally time again and finished my endstop board, installed it and wanted to give it a final test…
Everything looked fine so far, Motors are moving, but…
I can’t restore my settings from the archive file i created last time. The widget does open, but when i go to the carot next to save and click on “Archive/restore from local file”, nothing happens.
Only on the left side it says “Edit in JSFiddle Results”
I found some older discussions in which the problem was solved in the end.
What am I missing, any suggestions?
I’m using a Due + gShield G2 V87.01
