: Checking whether you have configured LaserWeb : : Version currently Installed :
: Version currently Installed : 30150
: Version available online on Github : 30150
: NB: UPDATE AVAILABLE! - Execute ‘git pull’ from your laserweb terminal
Uh, did that twice still got this.
Worked. Thanks.
The tab redraws get confused after opening some files so the layers don’t redraw correctly, it instead sometimes combines tabs until I click ALL, trace and bitmap tabs a few times. I also end up hitting reset view every time I open. Not sure how it all should work yet but there certainly are things that are confusing and have inconsistent behavior. As someone else said, positioning and scaling are not intuitive and opened files may be so large they don’t show until you scale.
It’s getting there! :slight_smile:
Uh, Peter, opening a file so you can see the entire thing (full extent bounding box) and scaling the VIEW is what most programs do, not bring it in scaled so big it does not look like it is there until you change the settings, which are not open by default.
