I’ve added an IR probe recently and now have 15 spearate (single) wires going to the cartridge (2 hotends, 2 fans, probe) - which seems a lot.
If I would use common GND and 24V wires I could reduce it down to 10. Has anyone done that?
Also, what cables are people using? Would it make sense to use some sort of multi wire cable loom? Are you using cables that are resistant to heat/flames/vibrations?
Typically all the +24vdc lines can be combined into one wire with enough current capacity. Grounds are switched by the MOSFET on the controller so you need separate wires for those. Always-on loads like lights and hot end fans can be totally combined if you want. Steppers and temp sensors need dedicated wiring.
I’m pondering this sort of thing at the moment too. I have 15 wires too (direct drive extruder). Also connectors at the hot end - I like the idea of one common connector for all wires rather than a bunch of connectors or soldered connections but interested to hear what others are using?
I’d recommend against a single connector, simply because if you ever need to replace a part of it you need to replace the whole connector (unless you have the tools to properly remove the little pins from the plug). I’ve had this in the very beginning and it just didn’t work (and I think there’s a post from Eric about that somehwere buried deep down in the group). Also it’d have to be a pretty large one.
I ended up using Molex connectors, 4-pin for hotends, 2-pin for fans, another 4 pin for the IR probe, etc. I’ve made sure to use the opposite connector type for those I don’t want to swap accidentially (e.g. part cooling fan is male on the wiring loom and hotend cooling fan female).
This also gives me heaps of flexibility to plug in hotends in different configurations or use them in my other printer.
@SirGeekALot hmm, from my experience ribbon cables aren’t very robust and I’d be concerned about them simply not lasting (and potentially even frying my board).
@Julian_Dirks Just to clarify, I’m using 3 different carriages and tend to swap hotends between carriages (but not the fans). If hotend and fans were on the same plug it simply wouldn’t work
@Oliver_Seiler that’s the one! I like your modular hotend system. I’ve been toying with embedding header pins soldered to chopped up prototyping boards as junction points. I’ve built one at the top of my drag chain so permanent wires from control board there. Good point about having different plugs to avoid accidental frying…
@Oliver_Seiler I would not combine the grounds from 5V and 12/24V. If you somehow get a short, you could backfeed 12V to the 5V side of things. I have 11 wires for single hot end, fans, therm & senesor. its not pretty either. I though about combining the %v grounds and 12V grounds, but that gets me from 11 to 8 only.
