My apologies. I had already stayed up too late last night trying different settings, and quickly posted my issue in frustration. Thanks in advance.
LaserWeb information:
On the About page, I see that I have:
- Frontend version: 4.0.998
- Backend version: 4.0.136
My settings are:
"settings": {
"__version": "4.0.998",
"__selectedProfile": "Zacks-Laser-Ingraver",
"__latestRelease": "2019-11-26T10:42:57Z",
"showMachine": true,
"machineWidth": 660,
"machineHeight": 660,
"machineBeamDiameter": 0.2,
"machineBottomLeftX": 0,
"machineBottomLeftY": 0,
"machineFeedRange": {
"XY": {"min": 1, "max": 50000},
"Z": {"min": 1, "max": 50000},
"A": {"min": 1, "max": 50000},
"S": {"min": 0, "max": 30000}
"machineXYProbeOffset": 0,
"machineZEnabled": false,
"machineZMatThickness": 0,
"machineZToolOffset": 0,
"machineZStartHeight": "",
"machineZProbeOffset": 0,
"machineAEnabled": false,
"machineBlowerEnabled": false,
"machineBlowerGcodeOn": "",
"machineBlowerGcodeOff": "",
"pxPerInch": 96,
"forcePxPerInch": false,
"dpiBitmap": 300,
"toolGridWidth": 660,
"toolGridHeight": 660,
"toolGridMinorSpacing": 10,
"toolGridMajorSpacing": 50,
"toolSafetyLockDisabled": true,
"toolCncMode": false,
"toolImagePosition": "BL",
"toolUseNumpad": true,
"toolDisplayCache": false,
"toolUseGamepad": false,
"toolCreateEmptyOps": false,
"toolVideoDevice": null,
"toolVideoPerspective": {"enabled": false},
"toolVideoLens": {"a": 1, "b": 1, "F": 1, "scale": 1},
"toolVideoFov": {"x": 1, "y": 1},
"toolVideoResolution": "720p(HD)",
"toolVideoOMR": false,
"toolVideoOMROffsetX": 0,
"toolVideoOMROffsetY": 0,
"toolVideoOMRMarkerSize": 20,
"toolWebcamUrl": "",
"toolFeedUnits": "mm/min",
"toolTestSValue": 1,
"toolTestDuration": 0,
"gcodeStart": "G21 ; Set units to mm\r\nG90 ; Absolute positioning\r\n",
"gcodeEnd": "M5 ; Switch tool offEnd\nG28",
"gcodeHoming": "",
"gcodeGenerator": "default",
"gcodeToolOn": "M4",
"gcodeToolOff": "M5",
"gcodeLaserIntensity": "S1000",
"gcodeLaserIntensitySeparateLine": false,
"gcodeSMinValue": 0,
"gcodeSMaxValue": 255,
"gcodeCheckSizePower": 100,
"gcodeToolTestPower": 100,
"gcodeToolTestDuration": 150,
"gcodeConcurrency": 2,
"gcodeCurvePrecision": 0.1,
"comServerVersion": "4.0.136",
"comServerIP": "localhost:8000",
"comServerConnect": false,
"comInterfaces": ["USB", "ESP8266", "Telnet"],
"comPorts": [
"comName": "COM3",
"manufacturer": "Intel",
"pnpId": "PCI\\VEN_8086&DEV_1E3D&SUBSYS_21F617AA&REV_04\\3&B1BFB68&0&B3",
"locationId": "PCI bus 0, device 22, function 3"
"comAccumulatedJobTime": 2782,
"connectVia": "USB",
"connectPort": "COM4",
"connectBaud": "115200",
"connectIP": "",
"jogStepsize": 10,
"jogFeedXY": 5000,
"jogFeedZ": 300,
"macros": {
"*GotoXY0": {
"label": "Goto XY zero",
"gcode": "G0 X0Y0",
"keybinding": "ctrl+f1",
"_locked": false
"*LaserOff": {
"label": "LASER OFF",
"gcode": "M5",
"keybinding": "ctrl+f2",
"_locked": false
"uiFcDrag": {"x": -298.4377291557339, "y": 8.41699992357735}
Problem description
I am unable to change laser’s power when using Laser Cut mode. I can’t seem to change any setting, including cut rate. No matter what setting I change on laserweb, the laser power and speed of the cut remains the same. If I use laser raster merge mode, the laser output will fluctuate with the PWM input. Thanks. Below are the first few lines of a simple circle I’m trying to engrave.
; Operation: 0
; Type: Laser Cut
; Paths: 1
; Passes: 1
; Cut rate: 1000 mm/min
; Pass 0
; Pass 0 Path 0
G0 X25.05 Y22.50
M4
G1 X25.10 Y22.50 S1000255.00 F1000
G1 X25.15 Y22.50
G1 X25.20 Y22.51
G1 X25.25 Y22.51
System description
- My machine is a diode laser
- I have a Arduino Board
- It has grbl 1.1h firmware
- I connect via USB
- My computer on which I run LaserWeb run is Windows version 10
Here is my configuration:
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=20.000
$101=20.000
$102=20.000
$110=3000.000
$111=3000.000
$112=3000.000
$120=10.000
$121=10.000
$122=10.000
$130=600.000
$131=600.000
$132=600.000
