Can you cut 3/8" (edit correction, 1/2") solid oak at 15mA in 3 passes at 4mm/s?
Why, yes, yes you can if everything else in the laser is working correctly. Oh, and if you’re using the 38.1" Fl. People thought 17mA was too high, so I tried it at 15mA, 10mA and 8ish-mA. Guess what happened each time? Sorry for the messiness in my workshop, I’ve been doing a lot of engraving and need to tidy things up and clean/perform maintenance on the machine.
@donkjr
+Don Kleinschnitz Jr. Hard to do stuff with a table saw you can do with the K40. I’m going to start making good sized house markers etc. with the 1/2". This example is 1/4" oak.
@JamieR very nice. I guess I will have to have a contest between my K40 and Cnc mill :).
You probably already said in another post but where did you get your 38.1 mm lens.
@donkjr no worries about individual posts they are cheap. I constantly wonder if I can get away with just a CNC, I use it more often cause it has a bigger area.
I eventually want to build a new frame and expand the size of my gantry to something like 2’x2’. I’d love to go for 3’ on the x, but don’t know if I’ll have enough room on my work bench. I can only buy a piece here and there and have to be frugal about it. Took me awhile just to make my Z, but it cost me less than $60 to do it. Drilled holes in the gantry and it’s pretty solid. Almost looks like one of the larger lasers that already have that type bed. I need to fix the idler wheels, or rather how I am supporting them, the screw/bolts are bending from the belt tension. A piece of metal and shorter bolt distance should do the trick.
