can we print one product using multi colured filaments with one extruded
Check out this product: https://www.kickstarter.com/projects/mosaic3d/the-palette-3d-printing-evolved/description
can Palette be used in one extruded
One extruder? Yeah it’s meant to
i have 3d stuffmaker Creator machine…can palette is useful for this machine
I believe so. It’s intended to work with any printer that doesn’t require proprietary filament
ok thanks
Its how i figured fdm colour could be done. Does it cut the filament and send them down the line or actually join them. The reason i ask is retraction.
@Michael_Scholtz From the information in the Kickstarter yes it joins them (just to clarify I don’t work for them, I didn’t even buy one yet. I’m waiting for it to fully release so I can see if it’s worth $400). They will apparently have software to generate a drip tower to deposit where the filament joins and mixes.
