Can someone help me?
Can someone help me? I’m just getting started with LaserWeb (I’m running a modded k40 and have been using Turnkey tyranny up until this point) and Im not sure if I installed it correctly. I followed the directions and using node.js installed it to my desktop. How do I launch the app? I ran one of the HTML files but that on its own doesn’t work.
@Marco_Salguero ​ welcome. Here follow the section to start the software. https://github.com/openhardwarecoza/LaserWeb3/wiki/Install:-Windows
Are you running arduino Marlin?
I am but I’m thinking of changing over to Smoothieware because I didn’t think LaserWeb worked with marlin. Thank you.
Yes it doesn’t work with marlin. Smoothie is just so much better. Anyway if you need further help just let us know
I am working with Marlin and lw3. It is not the best choice, but works.
@Roberbike ​ I agree but the overall experience is not there
+Peter van der Walt​ sorry but I am not a programmer. I am only an electronic. Actualy I use a version of marlin kimbra and lw to generate the gcode file and send it to the ramps with node server-marlin-experimental-ping-pong.
My computers are very old, pentiun iv and no all the time works fine to generate the gcode.
+Peter van der Walt​ yes, the word experimental can be droped. The connection with Marlin works well, and the raster also.
Only some times appear little errors like:
Unknown command
: "versión
:$fb
