Can someone help me with auto leveling with non conductive material such as wood and plastic
Put some aluminum foil down on the surface, hook it up as you normally would, and keep a hand on your emergency stop just in case
I had that idea I wasn’t sure if it would work wasn’t sure if foil was conductive enough to overcome any “noise” generated with the other components controlling the machine
Aluminum is very nicely conductive and there are several posts back in the ChiliPeppr group of people succeeding with this method on things like slate to get a mapping of the bumps before milling.
Would I solder a lead to the foil like you did to the pcb in your video on YouTube @jlauer
I’ve never been able to get a good solder joint on foil… I’d leave a little extra on one edge, fold it over several times so it won’t tear, and use an alligator clip.
Me too.
I have some conductive wire glue I will give it a shot and let the community know my results
I made a device that probes a surface and makes the electrical contact in the device, not the surface. You have to get the offset calculated back into the processing of the gcode. John mentioned a way to use the offset settings to make it calc correctly. Let me know if your interested and I can post a pic of it.
As John said, if you go back in the posts far enough (not sure if they roll off after a period of time) you may be able to see the post I did on this.
