Can someone help me out? I want to make an effect like this video. Here is my code, it is running a rainbow effect, I want to have it run select colors, Red Green and White.
if (setEffect == “Cyclon Rainbow”) { //Single Dot Down
static uint8_t hue = 0;
Serial.print(“x”);
// First slide the led in one direction
for(int i = 0; i < NUM_LEDS; i++) {
// Set the i’th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
// now that we’ve shown the leds, reset the i’th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(10);
for(int i = (NUM_LEDS)1; i >= 0; i-) {
// Show the leds
FastLED.show();
fadeall();
delay(10);
Speed change in what way? Did you experiment with changing that delay 40 numbers? You could also have it light up two LEDs at a time and advance twice as fast for example.
Also, comment out any Serial.print statements once you don’t need them for testing any more.
@marmil I want to be able to adjust how fast or slow the LEDs change color down the strip, the delay is how long the color sits at the end before changing and going back in reverse. But the speed it goes down the line is always the same, i’d like to be able to adjust it, i have different lengths LED strips and would like to be able to make them end/reverse at the same time
Hmmm… (after some unsuccessful attempts with LED strips off eBay) I’ve ordered some Christmas lights from Ray Wu… 6" apart… wonder if I can make a scale model of my house with tiny addressable LEDs to test code. Yes, I’m in over-thinking mode!
