Can I move two motors with a single axis?
Hi,
I’m new to Smoothieboard and smooothieware.
I would like to know if it is possible by modifying the config.txt configuration file to assign two different motors to the same CNC axis.
For example, when I send the G0 X10 command instead of moving only the X motor, also move the Z motor at the same time.
Thank you
This is really “slaving” the gamma driver to the alpha driver, rather than Z to X, from the perspective of smoothieware. At least one way is to disable gamma step, dir, and enable in config.txt (leave gamma_current correct), and use a jumper to connect STEP, DIR, and EN from the alpha driver to the gamma driver.
@Arthur_Wolf I don’t see config.txt options documented for configuration-drive axis slaving. Did I miss something?
First, thank you very much for the answer, I understood how to do it.
I found info here: http://smoothieware.org/laser-cutter-guide#doubling-stepper-motor-drivers
I thought there was some way to do it by configuration without having to resort to physical bridges.
thanks
