Can anyone with a AZSMZ-mini and a stepper on the 5th slot confirm, that the following pin-assignment is correct:
step_pin 2.8
dir_pin 2.13
en_pin 4.29
Thank you in advance!
step_pin 2.8
dir_pin 2.13
en_pin 4.29
so… +1 means, it is right?
No, it means +1. I hit every post I read with a +1 if it belongs here.
You’re probably better off going on a forum for that board. I’ve been on this community for two years and have never heard anything about it.
@Griffin_Paquette , there’s not really a forum for that board as far as I’m aware – the it’s some sort of knockoff smoothieware board, and from what I’ve heard (very little) is that they have a tendency to revise the board often, and forget to make the needed changes to the config, etc.
Yeah, @ThantiK is mostly right. I think, V2.1 is the first ‘real’ final version.
