Can anyone help me? I recently used krylon fusion plastic paint to paint an ABS item. The paint stays on fine. My problen is that the items are finger “armor” so, for example, when I type or touch something, the red paint leaves red marks on the items, like my keyboard. Is there a way to prevent this with another product?
Some sort of enamel or clear coat perhaps?
I will have to try that
thank you!
A glossy coating possible followed by a dull coating (dual coating for durability) should fix that.
But you probably want to use another paint if that one does not stick.
Or use a primer before painting…
