Can anybody tell me why i am printing mirror images of my models? I printed a name plate and the text came out backwards.
Your axis positions are reversed for X and/or Y.
You can also do this switch in the firmware if you feel like playing around in there.
could i change this in kisslicer instead?
yes i would rather do the firmware option
I had this issue on my first printer, and I originally flipped the hardware. Eventually, I made all of the connectors face the same way (the four visible metal points in the connector facing the driver chip) and modified the firmware. That way, reassembling it didn’t require me to guess what direction they should go when plugged in.
thank you all for the replies. I fixed my issue by moving the endstop min connections over one place to the endstop max positions and updated the firmware to home at the max endstop as opposed to the min endstop
