Cam2D UI. The Prismatic Widget created the 2D operations from the 3D mesh.
Cam2D UI. The Prismatic Widget created the 2D operations from the 3D mesh. I still have to hook up the jscut algorithms.
Lookin’ good. If you want to make your buttons look ChiliPeppr-ish, just add the class “btn btn-default” to your HTML tags.
@jlauer done. That also helped with a vertical alignment problem with nearby text :slight_smile:
You might also consider adding class “form-control” to your input or select elements. I tend to refer to http://getbootstrap.com/css/#forms a lot while tossing UI elements together. I like to use class “add-on” for units at the end of input boxes for units to help folks know what unit they’re entering.
I can attest to doing and second all the things being suggested above.
+Peter van der Walt done. It makes it a bit easier to see what’s going on.
