Buildtak and @Printrbot sticking well together. Almost too good, got my first layer too close.
Yeah, in my first test with buildtak, it was impossible to remove the print without tearing the buildtak material. It stuck well, but a material that is going to be that difficult to release needs to be a lot stronger.
Yup, tore some off already. Trying to find ideal distance.
I’m not about to put oil on my bed, kinda defeats the purpose of BuildTak…which should be the ideal surface. Just experimenting with a set it and forget it surface. Looks like it’s truly elusive.
would adding heat or making everything cold help at all? i am thinking either cranking up the heated bed, or moving the build plate to the refrigerator/freezer.
