Anyone know where I could get a blank acrylic hanging LED Bar Sign in the UK? prob the 30 x 20cm size - the type you see in bars, mainly in the US. I was looking to engrave the sign to create a bar sign for myself.
I can’t seem to find any blank ones - they all seem engraved already
thanks I got some of them - I was looking the larger one that you might see hanging in bars - maybe 12" by 5"
from description the wooden one is 5.89 inch wide / Acrilic height is up to you
This is “Maker Forums” - make one
I have tested a few of these holders. From my experience, the black ones are quite fragile, the USB connector is hard to connect with the cable, and sometimes if breaks. I had to open the case and weld a new connector inside, which took me some time.
The white ones are stronger, I’ve had no problem with them so far.
They require 4mm thick acrylic. For the ones I got, the width of the slot is 8cm for the black ones and 7cm for the white ones. Sometimes, the seller provides this information, not always.
When inserting the acrylic, there was no problem for the black ones, but I had to force to insert it in the white ones.
You can find them down to 3 USD on Aliexpress (plus shipping)
