need an expert to recommend the best software to create STL files that contain text (words and letters).
I need to be able to mirror the letters in order to produce blocks similar to old-fashioned typesetting.
Most CAD packages will do that.
I use Fusion 360. I believe SketchUp will do the same.
I’m pretty sure I recently saw a tutorial for doing that with FreeCAD, too.
could you try something like this?
I’ve always done it with FreeCAD. But I believe you can do it in OpenSCAD, too.
Yes, I’ve done this in OpenSCAD both by importing an SVG and by using its built-in text support.
Yes, Its pretty easy to do with FreeCAD. Modified the Maglower of the Caliburn nerf gun to put my wifes name on it. I used a Star Trek font I found online.
I’m also use Fusion 360 and works very well!!
