As described in http://repstrapdk.blogspot.de/2017/05/the-re-birth-of-z-probe-mount-and.html?m=1, my Mendel90 (sturdy) prints a lot better when under fairly high tension, right below where the belt jumps off. To avoid embarrassing belt jumping-off incidents, I’ve considered changing the gear on the X axis shaft to having a flange, stopping the belt. But nophead usually knows what he’s doing, so - is there a reason the belt gears shouldn’t have flanges?
Too many flanges adds drag and wears the edges of the belt. You generally want to use the minimum required to keep the drive working. Particularly with printed pulleys where the top flange is a nasty overhang or a separate part.
@Alex_Wiebe crowning a timing pulley makes the tooth pitch vary from center to edge and the belts rapidly self-destruct. What they do instead for self-tracking timing belts is herringbone belt teeth. It’s not done in our belt size range but common in big industrial belts.
Thanks for pointing out the downsides of crowning, I was thinking of that as a way to simplify printing, but won’t. It’s entirely possible the pulley is flangeless simply because it’s easier to print.
both my mendel90’s have flanged pulleys (aluminium, not printed), they seem to work ok. I don’t have the belt super tight, so much that it tries to bend things.
@Lars_Clausen I think polyurethane T2.5 (metric trapezoid tooth profile). Was a really popular early RepRap option. Easier to model and print pulleys than modern curvilinear profiles with smaller teeth like 2mm GT2.
Flanges prevent the belt slipping off but if the belt rubs against the flange anything more than lightly it can cause it to ride up and give positional errors.
To make it run in the centre the motor shaft needs to be perfectly perpendicular. Sounds like you are pulling the motor out of line.
Perhaps try loosening the screws and shifting the front to the right.
