Hi all-
I thought to post this update- my machine has been displaying symptom of a worn out bearing on the carriage. After I went looking, sure enough, its on the Y axis. If i rock the carriage I can feel the play in the shaft. I get this funny layer registration when Z-hoping. Successive layers are just off enough to be noticed.
I mic’d the shaft and it is literally dead nuts on 8mm with my metric mic and vernier. I have a set of spares to swap back in to see how they do.
Reading the Spyraflo specs on the oil impregnated bronze bushings, the MINIMUM bearing ID size is 8.03. They have a PTFE composite version that is 7.98 min ID that I might try. I cant check the bushing until I get it pulled.
Aside from the sources in the BOM, SDP/SI, the Spyraflo bearings can be gotten from McMaster, https://www.mcmaster.com/standard-sleeve-bearings
Spyraflo directed me to Quality Bearings and Components. The have a $30 minimum order though. Link as of this posting-
https://www.qbcbearings.com/Buy/Pressbearings.php
Waiting to hear back on pricing and stock for now.
EDIT: QBC is actually SDP/SI.
Dennis
