Axis not moving, but homing works
I am using Marlin on RAMPS for driving the printer. It was working fine.
But now the XYZ axis are not moving for axis +/- commands, but when I give home command all the Axis are homed correctly.
Not sure how to debug
I had this problem on my PrintrBot Simple when I tried to switch to an E3D hot end. Turns out I had shorted my thermistor, and some safety in Marlin wouldn’t allow the jog movements, but would allow homing.
tl;dr: Check your hot end thermistor and its connections. Weird cause, but it happened to me.
Thanks for the info, I will check and update. Also I remember noticing 0 as temp
Sounds like you broke a wire or a connection came loose on your thermistor.
update: as you said the thermistor was faulty, after disabling thermistor in marlin firmware, it works. Thanks for the help
“Well, then I’m happy and sad for you.” (Lazlo Hollyfeld, in Real Genius)
Hope you can get a new thermistor soon.
