Axis locked alarm when using GrblGru
Hi
When i try to send gcodes to the mks genl v1 board from grblgru to grbl-mega-5x it appears an alarm tells that the Axis are locked , how to fix it
Axes are locked until ytou home the machine. This is to avoid crashes from the machine not knowing where the tool is located.
You can try
a) Press the ‘unlock’ then use jog controls
b) Set the position of all axes manually to what you estimate they are
c) try a different software (e.g. Universal GCode Sender)
Once you know that all axes and limit swiches are working you can simply
d) home the machine (assumes everything is setup and working)
Thanks i will try that and see if it work.
Another question, if i want to try to home all axes with $H command do all endstops should be plugged, because when i tried this an alarm shows up within a few seconds and the axes didn’t move or home
