Are there plans to allow for variable print bed sizes? I have a MixShop G1 with a 170 x 175 print bed. It is obviously important when controlling the printer manually from the app.
@Carole_Davidson yes, I started the work already. But why is it important when controlling the printer manually ?
Quite often I move the head using the host software - for leveling of the bed. I home the axis and the host will restrict the travel to the bed limits if I should accidentally overshoot the limits. It would be helpful if this could be incorporated in your software.
@Carole_Davidson oh, I thought other host software like pronterface would allow to overshoot as well. Anyhow, I will add this feature.
I currently use Repetier-Host from my PC. Thank-you for your efforts. I will certainly use the GCodePrintr from my Samsung Tab Pro 12.2 when the feature is added.
