Are any of. You guys with big silicone beds using solid state relays to power them. My ramps 1.4 board cant deal with the amps my qu-bd bed pulls. It starts for just a second and shuts down.
I ordered a 40 amp SSR from amazon to add into the circuit. Just curious if any of you had done this already.
@Joe_Spanier
Sorry, no pics, currently in a big overhaul/redesign of my extruder.
I’m using PID, no problems. Wiring is simple, just keep in mind that polarity is critical for the input side of the SSR.
@ThantiK Ya thats what i keep hearing. I have never been able to successfully load the firmware into my printerboard. After configuring the Confh.h file the generate the HEX file. That’s all OK. But when i go to flash the ARV dude says file name incorrect. I have changed the file names to match. I never got into it farther as BB was working. I think it may also be a HID bootloader thing. I should try a different bootloader. This why next i will use RAMPS and Arduino or some other flavor to get away from this type of flashing the firmware.
