Anyone willing to help out doing a testprint?
I have extended the screw 3mm because of it sometime getting stuck while “reversing” from a closed position. As a result the bigger piece of support might be easier to remove but on the other hand the part with the screw might be harder to loosen. Let me know.
If someone is willing to try printing this new version and report back i would be very thankful.
If you could specify what printer and settings was used that would be awesome!
Updated file is: Printable Wrench W Longer Screw.stl
http://www.thingiverse.com/thing:139268
Maybe time to start a print tomorrow after work. Ok with PLA? 0.2mm height.
