Anyone tried messing with a MKR1000?
Anyone tried messing with a MKR1000? I have a couple strips that I’ve bought through the years. Seems the only one that works is 5V. The rest are 12V that I connect through a breadboard with common ground and I get nothing. The same setup works with an arduino due. Thoughts?
Are you using a level shifter? (Some arm chips need to have one more than others, i have thoughts on why it sometimes is necessary and why it sometimes isn’t - but for the most part, it should at least be attempted)
