Anyone know off the top of their head what the cura command is for lowering the z axis by 0.1 mm after the z probe has been activated, my hot end is just off by literally nothing and I don’t want to unscrew the z probe for that small amount. thanks
Running marlin?
@Markus_Granberg Yup
Adjust the z offset on the printer and save to eeprom.
Use the M851 command it’s what you are supposed to do. M851 Z-xx
test the Marlin3DprinterTool… It helps you get the M851 command right. Then you can adjust the M851 for the paper thickness.
Here is a video: https://www.youtube.com/watch?v=7Bwmh1lIMcg
(The video will be updated with the latest version)
Everything that M3DpT does can be done with GCODE. Its just do all that work for you…
