And old friend has had this Lightobjects Cool Master-500 sitting around for years, didn’t know what had gone wrong and gave it to me. Trouble shot it to the water tank thermistor, found it’s a 10K NTC M8 thread thermistor and replaced along with isolating really annoying pump motor chassis vibrations.
So now it works but I have no clue how to set temps on it. The SET button does let me set a temp down to 20C but it won’t stick/stay. What’s the magic sequence? Anyone
yup and tried long press on the down arrow. I’d found a video, no sound, which shows pressing RST+up then SET+up and getting some codes. I don’t know what it means since there was no sound but it’s an odd setup with docs required for things like F0, F1, F2 etc codes. weird
It does look like the CW-5000 chiller has the same button configuration(RST,SET,up,down) and the programming looks what I saw:
Sections 3 and 4 show Error codes which look right( I’d had an E3 when the temp sensor was showing -17C ) and in section 4 it shows Fn numbers which mapped to a video without sound I saw showing F0 or something like that being used.
I got something working which acts right and it repeats after power cycle. It’ll operate from 21C to 17.9C which is a good window for CO2 tubes.
