Anyone know an alternate source for the A 7Z 4MF2208 part in the Eustathios BOM?
Its the flanged pillow block for the Z-axis and its currently out of stock at SDP-SI.
I’m guessing it wouldn’t be too hard to swap out with any other 8mm bore pillowblock with bearing, but I think it would need a redesign of the printed part it mounts onto.
If you have solidworks and are adventurous… I have a new version I am working on that uses 608zz bearings in place of the pillow block bushing. It is not done yet, but can give you some thing to work with: https://github.com/eclsnowman/Eustathios-V2/tree/master/Solidworks%20Models
I’ll give that a go tonight, thanks Eric!
I found these, http://www.ebay.com/itm/like/231452345160?lpid=82&chn=ps, but I’m not sure if their mounting holes are the same 38mm apart.
