Anyone in US interested to get their hands on “Dauerdruckplatte” aluminum PEI coated with red colored finish? I actually just want one for myself but the supplier in German has minimum order of 5 plates… the plate is for prusa i3 so would fit MK2 pcb heater dimension
Update1:
plate dimension 216mm x 216mm x 5mm with holes 209x209 mm apart square total shipped to california 260 Euro
Let me know if there’s enough interest
@Hakan_Evirgen filafarm products are completely different. They still sell PEI-Sheets or CFK/GFK with PEI Sheets glued on. And the other one product they sell, their so called “precision-plates”, are totally the same as @Step_Cia mentioned above, with nearly the same pricetag. Not to mention, that they jumped on the train very late…
@Rene_Jurack can you explain this more in detail? Until now I had only Filaprint. So I do not know, what else is there and what is best suitable for what.
@Hakan_Evirgen Imagine all the pro’s of your experience with filaprint and add to this a perfectly machined flatness, rigidness and also the possibility of automatic contact-free bedleveling. Furthermore add better energy efficiency when heated and longer durability.
@Rene_Jurack so then what would you recommend for me? For a couple of days I have the bq Prusa i3 Hephestos 2, which has print bed of A4 size and does not have a heated bed. So I want to have a heated bed for it as well as permanent printing plate/coating/whatever. And where to buy in Europe?
Cool. If i didn’t care about the color but needed a PEI coated alu plate in 300x300mm for a Lulzbot Taz, where would be the best place to find one for shipment to the US?
cost is higher though $72 each plate so @Evan_Nguyen I won’t hold you if you decide not to go through. Let me know I will offer it to someone else. thx
