Anyone have reco’s on where I’m going wrong extracting data from a text file (SD) and sending along DMX? The code works for the P9813 portion and the DMX works in general but not the SD data.
I believe my issue is at line 68. I think this is reading too many values. IE currentColor is storing 5 values (5 lights) vs 1 Hex or 3xR/G/B.
The values in the SD for consideration are…“727a 6276 3030 …”. I believe these bytes should be each DMX channels PWM value, no?
Thanks
http://pastebin.com/WUeruMKK
