Anyone have luck with the F104 tires Daniel released a few weeks back? They are accurate when printed (44mm front and 47mm rear) but are a probably around 3mm short of fitting the Tamiya F104 tires properly, any scaling results in the bearing hole becoming to big.
Those are the rims and tires used in this video: https://youtu.be/KFZyC3p2EY4
If you have problem with those you can try these: http://www.thingiverse.com/thing:1462917
