Anyone have any recommendations for connectors for led tape, I need something fairly low profile to be able to install tape easily without having to solder directly to the tape, soldering the connector prior to installation is no problem.
There are snap-lock connectors… Hang on
You can get 2-3-4 pin ones: http://www.aliexpress.com/item/Free-Shipping-RGB-LED-Strip-Connector-LED-Connector-For-RGB-LED-Strip-5050-3528-LED-Light/1421626588.html
thanks Mike.
