Anybody know where I can get small metal pins to bind two pieces together I am looking to make dials for few games and I need pins to hold two pieces together that would allow free movement
Maybe a double side rivet or a chicago screw
Something like this? They have a variety of lengths and diameters. “Steel dowel pin” seems to be a good search term. If you can’t find the exact size you want, you might could try finding round bar/rod stock of the correct diameter and then cut to length. https://www.amazon.com/Stainless-Steel-15-8mm-Fasten-Elements/dp/B00B3MFRRK
@Nedman thanks Ned found some of these on eBay in the size I need
