Any suggestions how I can get rid of this?
Wood filament seems to crumble even with 0.85 extrusionmultiplier. Diameter set correctly, e steps are correct. I only have this with laywood. Turning down temp to 205 deg helped a bit but not much…
Bigger Nozzle size, no flat nozzle like E3D ones, much more and harder cooling on the print
Ok more cooling is possible. But nozzles mhh. Ive got an e3d ^^ ill try maybe ill tune it spiky on a lathe
I new from the picture what nozle you are using
Just buy a nozzle for 0,50€ with M6 thread looking like these: https://m.aliexpress.com/item/32655423030.html?aff_click_id=c7d41823974f451998ccc2b2ca039b33-1463572913927-09901-eub6yrrBy&aff_platform=y
@Rene_Jurack like old jhead nozzles mhh
