Any one tried running Chilipeppr form Raspberry PI 2 or 3?
Any one tried running Chilipeppr form Raspberry PI 2 or 3? If yes on which browser?
I previously tried it on PI 2 but none of the browsers I tested (Rasbian default browser and chrome) was able to fully load CP.
It is better to run Serial Port JSON Server on rPi and use more powerful machine to run Chilipeppr. All you need is to connect to the SPJS using the IP address of your rPi in Chilipeppr. You may also add SPJS to the autostart, so it will work out of the box every time you start the Pi.
Your CNC should be connected to rPi and the Chilipeppr PC doesn’t need to be placed next to it, but needs to be connected to the same network.
Ya I know, that’s pritty much my setup now. But I’m looking into other possibilities.
I tried the Pi-2 and Pi-3, various distros, etc. Web-GL is the issue. The only thing that has shown promise is the ODROID-C2 running android.
