Any idea if the thermistor (100k, 3%) and resistance (5.6 ohm or 6.8 ohm) of the J-Head Mk V-BV are compatible with a ToM MK6?
The heater board seems to use a 5% thermistos http://www.thingiverse.com/thing:16450 https://www.hotends.com/index.php?route=product/product&product_id=88
The resistor for heating should be fine. Does your firmware not support changing thermistor profiles?
Never tried it. Firmware is Sailfish.
http://reprap.org/wiki/List_of_Firmware#Sailfish Doesn’t list anything like that.
I’ll check into that …at some point. Too busy even to think of setting up a build environment on a Mac to compile a firmware for the Thing-o-Matic mainboard and one for the extruder-controller board.
