I am doing something wrong. Windows 7, if I even unpack the exe file from the Zip file, Windows Security Essentials says “Detected threats are being cleaned” and the folder is empty.
I downloaded 3.39.0 from the GrblGru website. I’m very interested in drag knife support.
@GrblGru note there is a way to submit the files as a software developer and you can say you believe it was incorrectly identified. I think that requires an MSDN account but since you are writing windows-only software I suspect you’ve already done that.
@Steven_Greenfield you can submit the file as a home user without creating an account, or create an account if necessary in order to follow up.
Sorry, I just saw that I’m late again, but I saw also that the problem could be solved.
Maybe I can add the hint that I check GrblGru regularly with a very professional and unfortunately also very expensive program or viruses.
@Steven_Greenfield
You’re welcome, of course. It’s been a while since I developed the drag knife mode. I don’t know if you know the video I’ve attached here.
Please let me know if you have any problems. I am very sure that we can get this to work.
