Another set of questions not all related to each other.
How important is the base the OX is on? I had to move mine temporarily to the garage and it’s sitting on a piece of plywood across two sawhorses. There are 2 layers of 5/8" MDF as the spoil board base and neither are fixed to the machine at all other than just laying on top of the supports - is this going to give me extra vibration that will cause part of my issues (I am 99.9% sure the answer is yes)?
How do you guys use cutting oil on a MDF spoil board? Doesn’t it just soak in and destroy that area in one cut (once it gets damp it swells)?
I used rubbing alcohol when I tapped the holes during construction and read that it’s a great lube/cutting oil for aluminum - but isn’t it flammable (as with WD-40, kero, etc)? If the bit gets hot enough to smoke, how do they not ignite?
I’d love to use some kind of auto-spray coolant but I’m worried about the spindle being exposed as it is - is the 400W spindle sealed?
Has anyone ever setup a non-spindle spindle that uses a regular larger motor on backside of the X gantry with a belt to the non-motorized spindle on front?
Is it possible to do what I described in #5 and keep accuracy without having to buy the $700 liquid cooled spindle if I want more cutting power? (Or do I just go up to a regular wood router?)
