And @Mark_Estes ’ demos (my best of sample) running in their natural habitat of 64x64, even if my 1m^2 panel is a bit bigger than Mark’s table, and my pixels aren’t layed out as well, it still looks quite good.
Of course huge thanks to @Yves_BAZIN for his help and encouragement during my build, even if I’m not using his driver yet (I’m using @Sam_Guyer 's driver which is 2x slower, but still gives me around 50fps, so good enough)
@Yves_BAZIN Music is Above and Beyond Acoustic concert: https://www.youtube.com/watch?v=CNUTlKqSO-I (in case you hadn’t noticed yet, I’m a trance fan, although this concert played the instrumental parts of their famous trance tracks)
@Mark_Estes you did all the work, making your code work with my matrices, was pretty easy. The longest part was watching your 110 demos or so, and selecting the ones I liked the most
I then added a bit of code to control the current running pattern via serial port and allow jumping through a sub-section of your demos.
