an updated video which shows the results I most commonly see.
an updated video which shows the results I most commonly see. Any ideas?
It seem that your tip is off
Try to mess around with that a bit and look for problems,
And i think your printing from too high off the platform
No, your first layer is too low, and either your e_steps/mm is way off or you’re not getting any grip on the filament.
a temp change on the heated bed to 115 did the trick as well as adjusting the first layer. works like a charm now
I think your travel speed is too high, causes what I think of as whiplash when it stops.
