An electronic enclosure for my Shapeoko2
Really nice! I’m surprised you didn’t the put two fans in series to avoid the buck converter
The design on this is great. What software did you use? And what did you use for CAM?
@Frank_Graffagnino Thanks.
I also added a LED ring under my DC spindle. That is also using 12V. BTW, had to do several iterations to get the length of this box < 30cm, that is the maximum I can cut in my machine. I initially thought about two fan setup, but later gave it up due to that.
Modeled in Solidworks.
