Am about to install the heated conveyor belt -tensioner to my #ThingOMatic . The belt itself is already replaced with 0.025mm titanium with a Kapton surface.
The missing tensioning mechanism is some heavy oversight in the original @MakerBot1 Industries design as is the original plastic belt that expands+warps due to temperature (‘heated’ conveyot belt hint) and wear, is slightly too short after purchase because it hasn’t expanded yet and the completely missing bed-leveling mechanism.
Designing a shortened lever-arm for this one as the lower bolt is a bit higher due to my removable ABP mod.
( (moved) Thing-O-Matic: Removable ABP mod by MarcusWolschon - Thingiverse This allows me to quickly replace the belt with e.g. my PCB routing platform (moved) PCB routing build platform for Thing-O-Matic by MarcusWolschon - Thingiverse to mill electronics.).
Have to start from scratch as there are no original design files for the tensioner are posted. Only an STL export and only as a complete bed of 4 parts.
ToM APB Belt Tensioner by gaerisl - Thingiverse
