Aluminum extrusion all cut to size thanks to Mike Smith.
Aluminum extrusion all cut to size thanks to Mike Smith. Do you need to drills and tap or can you use the brackets that Misumi provides?
I assume this is a Eustathios? If so I recommend doing both the threaded ends with matching cross holes in the extrusion to allow axis to the buttonhead, and the misumi corner brackets. This makes for a very ridged frame.
@Eclsnowman Yes this will be an Eustathios with 2 variations. Increase height and the bottom will have extrusion around the base rather than have legs. This will be to inclose all electronics. Thanks for the advice.
