@Yves_BAZIN good tip ! Thanks!!
@Jeroen_van_Dorsten yes, if you are doing parallel output, you are most likely getting cross talk between the wires. The ferrite Yves suggested, helps, but otherwise you really want twisted pair (cat-5) to twist every signal line with a ground line. You don’t need cat-6, any cat-xx will do IMO.
Lowering voltage on one PSU got me through the night luckily . Definitely changing wires next week. Thanks again for the advice
This was last night . Got a little wasted
@Jeroen_van_Dorsten top cool congrats it looks amazing !! You’re right to have some fun too after that stuff you totally deserved it.
