I have an issue. I’m trying to convert a .stl to a .gcode for chilipeppr to cut. Its a 3d image of Alaska, but VCarve Pro will import it as a model, but won’t convert it to a machinable / tool path. I know the code is very similar, but CP wouldn’t accept it either. Is there a solution I’m over looking? I had hoped a software as expensive as VCarve would chew it up without a problem.
I’ll give that a try too. Right now, I’m making super slow headway. I found out Vcarve Pro (VCP) will do it, but since I can’t find any tutorials and I’m inexperienced… Its really slow moving.
I found going into “create a tool path” and using “roughing tool path” will get me to an initial cutting.
I’m trying to do 3d. I’m looking at Fusion but it won’t import. The file shows as a meshmixer. At this point I can’t get it into Fusion360 either. I was having better luck with VCarve.
