@Alex_Lee @Eclsnowman how scalable is the Spartan? Can I double the X,Y,Z With out issue?
@Alex_Krause I’m not sure about going twice as big, that would translate on 4 times the printable area and volume, so weight on the Y axis may be a bit of an issue, driving a huge build plate and also having to deal with some deflection. But that’s all my own theory, you can try to prove me wrong
my have to try
My first self build was a gmax, I had a lot of issues with trying to get the 18x18 moving bed flat/ leveled/ rigid. I solved that with my sheet metal machines, but it didn’t solve the weight issue of printing with a cnc frame essentially. I’m convinced that a box build is the way to go for ideal quality. If you want 400x400 build a Herculien.
