Alaska Topo 3d Print, using PLA on BCN3D Sigma. The print was printed directly on a 1/4 piece of mdf and the mdf will be used to display these piece.
Looks like excellent adhesion on the MDF. Did you have any issues leveling the MDF surface?
Just tape the corners of the mdf sheet on the build platform. put a little glue stick on the sheet and started the print. The BCN3D has it z sensor on the hot end rather then build platform so there was no need for any z height adjustment as well.
hey thats my home of Alaska i live by bethel
