Again a question about IR + AVR + WS2812: @Daniel_Garcia writes “The problem is not with the library, the problem is with the combination of LEDs (neopixel/ws2812) and the MCU being used (air based arduinos). The WS2812 timing requirements are pretty tight - so interrupts have to be disabled while writing out data for them.”
What I understand is: On an AVR it is (so far) impossible to have an ISR so short that it could be completely executed while pushing out a frame inbetween sending the data of 2 LEDs. So the interrupted frame will be incomplete because the required timing grid is too tight.
If the animation itself is programmed slow and smooth - who would care about one incomplete frame inbetween? Would it even be visible?
So why not just allowing interrupts in general? What am I overlooking here?
